Extract firmware of player using the S1fwx tool
Old 21st Jul 2007, 9:25 am
wkhattak, What video format does it use?
Old 21st Jul 2007, 9:30 am
In the documentation it says that it uses "proprietary .AMV" format.
thanks,
Old 22nd Jul 2007, 5:07 pm
S1mp3.org has a database of 9x firmwares, as well as others ^__^
http://forum.s1mp3.org/viewtopic.php?t=6655
Go to the FW features page to check out the rest.
Hope this helps.
Old 23rd Jul 2007, 6:36 am
thanks 'smoke', but none of the models match my player
Old 24th Jul 2007, 6:00 am
X__x;; 9.0.50 is the first firmware on the list. I was under the impression that they were all the same, but it seems I am mistaken. Perhaps you could ask at s1mp3.org
  #16 (permalink)
Old 24th Jul 2007, 1:14 pm
thanks for the suggestion
s1fwx v3.3 is not able to extract 9.1.52 firmware niks Support and How To 1 7th Dec 2008 11:28 pm
Tool for Extract FirmWare dynamic503 Support and How To 3 18th Jan 2008 10:50 pm
Problems durind repair my fw with s1fwx tool kathmandu Mods and Themes 1 12th Oct 2007 8:04 am
using S1fwx tool amcbiker General Discussion 2 6th Feb 2007 3:31 pm
How to: extract firmware of your player using the S1fwx tool admin Knowledge Base and FAQ 0 3rd Apr 2006 1:23 am
