problem with firmware extraction
Old 7th Jul 2007, 7:32 pm
Default problem with firmware extraction
Hi all , i have a problem when i try to extract the firmware from my generic 1 gb mp3 player , i follow the instructions from here http://www.mympxplayer.org/viewtopic.php?t=66 , the program gives me a error
<a>..<z> select device
<.> scan for devices
<?> display help
<~> exit program
$d
connect to device 'D:\'...
init device...
set device to f-mode...
get info from device...
device = 'S1 Mp3 Player'
firmware type = 'F285'
firmware version = 9.0.50
read boot record...
detect firmware size...
error: The system cannot read from the specified device.
read flash...
write to file 'dump.bin'...
filename = 'dump.bin'
filetype = afi
md5 = 5EE43264955DF7227436C4BAB53EF681
file id = 'AFI '
vendor id = 0x6977
product id = 0x6552
version = 9.0.50
date = 00/00/0000
| BRECF285.BIN | | 16kb | | F285 | | B | | 27A0A2E8 |
filetype = unknown
disconnect from device...
success.
Press any key to continue . . .
the program extracts just one 6 mb file ( dump.bin ) , not like in this picture from the guide
when i run repair.bat , its say
s1fwx v2.6 - copyright (c) 2005 wiRe (http://www.s1mp3.de/)
repair dumped firmware file...
backup file to 'dump.bi$'...
try to repair firmware...
error: unknown firmware file, repairing file failed
i dont know what is happening , the player works fine , can the firmware still be "broken" ?
and if i try to open the bin file in s1res.exe i have an error
any ideas ?
where i can find a more actual firmware for this player ?
Thanks.
Old 7th Jul 2007, 7:44 pm
bahiense,
The reason you can't extract your players firmware is because s1fwx cannot extract it.
You're player is using FW version 9.0.50. S1fwx can only correctly extract and repair version 9.0.43 and below.
You should not attempt to flash any other firmware to your player as there are so many different versions out there you will most likely choose the wrong one and end up disabling it. Finding a compatible replacement can be almost impossible.
If your player works fine then leave it. Enjoy it.
It's much better to have a working player then a dead one.
[hr:43af44b395]
Firmware Extraction problem with Rockchip player madao Support and How To 1 13th Jun 2009 11:29 am
9.0.50 firmware extraction problem. MusicBOY General Discussion 1 26th Mar 2007 6:58 pm
firmware extraction paolino70 Support and How To 0 20th Dec 2006 7:52 am
Firmware extraction broose Support and How To 1 4th Dec 2006 5:36 pm
Firmware Extraction Parsec Support and How To 1 15th Nov 2006 8:31 am
