Help Unknown Mp3
Old 9th Jul 2007, 8:15 am
Default Help Unknown Mp3
Hi,
A friend of mine just came to me cuz his mp3 was dead (would not even start up) so i`ve rewriten it with some sigmatel firmware, works now but it won`t show anything on the screen and buttons are screwed up(instead of next track it activates volume and so on) on the casing it says Tom-Tec
The player has 1 gb
I`ve opened the mp3 and i see that it uses a :
Sigmatel
Stmp3502
L 100E - CA6
this is what i got from Ucheckdisk
Logic Driver: I:\
VID&PID: Vid_066f&Pid_8000
Speed: full speed
VendorID: SigmaTel
ProductID: MSCN
Product Revision: 0100
Vendor Description: <USB>
Product Description: <USB>
Serial Number: 23DE9085F2228487
so if any1 could help me find a firmware that works would be great( i`ve allready tryed the sigmatel from the download section the one with 1 gb memory)
Old 11th Jul 2007, 12:40 pm
Default Re: Help Unknown Mp3
well ? noone can help me out ?
Old 11th Jul 2007, 5:11 pm
Sekundes , Sigmatel firmwares are difficult to come by and the download section only hosts 3 copies of the Sigmatel firmwares here http://www.mympxplayer.org/sigmatel-firmware-dc36.html
Have a go at all of them and good luck.
An unknown asf file! trieu1985 Video related 0 11th Sep 2008 9:23 am
unknown mp4 need help sinclocker Dead Players 1 28th May 2008 9:51 pm
Unknown MP4 Player?, anyone know? MichiNRG General Discussion 2 9th Mar 2008 3:09 am
Unknown Firmware? Ramautet Support and How To 2 18th Nov 2006 11:00 pm
Firmware unknown darkspark2134 Support and How To 5 5th May 2006 3:26 am
