Problem with my Chipod
Old 16th Jul 2007, 8:28 am
Default Problem with my Chipod
Hi guys, I bought a chipod about 6 months ago. It has worked perfectly since buying it until recently. The issue I have is that if I bend/bump the player (even a little bit) it shuts doen then restarts. I use it a lot when i mow the lawn and just keep it in my back pocket. So, as i move around this seems to happen frequently. I assume its probably juist a poor soldering point or something but just wanted to see if anyone has had this problem.
Cheers
Old 16th Jul 2007, 9:34 am
I agree with you, sounds like a dry joint or poor connection considering you have had your player sometime and it has been working fine until now
:idea: I Can''''t wait to get my teeth into the mother of all mp3 players. THE M8 :P
Old 16th Jul 2007, 10:31 am
Heck, I'll agree with you. When I recently pulled one of my players apart to verify the memory, I loosened one end of a diode because I didn't realize one screw was a mm shorter than the others and was supposed to go there and only there. Imagine my horror when I pushed the on button and got nothing.
Took me about a half hour to figure out that the little bitty teeny weenie component on the very edge of the board was not quite straight. Another 15 minutes sticking it back in place and re-assembling the the thing and I'll agree with anyone who says something has come loose in theirs!
My two iPods are jealous of my two MPx players.
Old 16th Jul 2007, 12:43 pm
Default Re: Problem with my Chipod
Thanks for the replies. I was thinking about taking it apart but Ive never done it before and Im kinda scared to possibly screw the whole thing up.
Old 16th Jul 2007, 7:59 pm
sec126 , it could also possibly be a case of static causing the player to restart. Especially if you put in your pocket and move around.
Old 17th Jul 2007, 5:37 am
Well thats a good possability but Ive actually taken the player and bent it in my hand just a little bit and it did the same thing. The hourglass came up it restarted all over again.
Old 17th Jul 2007, 6:15 am
I have an old palm device that does the same thing. I'm fairly sure there is something loose inside, but I just haven't taken a look yet.
Videos on a chipod? Moon Video related 11 31st Oct 2008 11:04 pm
Need help with my actual chiPod buaman22 General Discussion 15 25th Aug 2007 8:06 pm
Got my new chipod! h2modmaster Support and How To 1 27th Apr 2007 7:49 pm
What do you think of Chipod ? Qinan General Discussion 8 14th Feb 2007 1:05 am
ChiPod experience Relikk General Discussion 4 12th Feb 2007 7:35 am
