Badly solded battery (or so i presume)
Old 16th Jul 2007, 7:17 pm
Default Badly solded battery (or so i presume)
I removed a memory hack from my supposedly 4gig chipod (turned out to be two) but now i still face another problem.
The battery has the tendency to act up, as in connecting sometimes when i attach it to the pc using the usb cable, but not when i just flick the switch on the player to on. I read something off another user on the board having a similar (yet not so similar otherwise i wouldnt be posting this thread) problem, and it worked for him to stick a little piece of cardboard over the battery pushing it closer to the connectors, but somehow i get the feeling that this won't work for me as i assume that his casing is different from mine. Mine is full-bodied metal. I will try the cardboard trick tomorrow, and see if this works; If not, i will be posting some pictures of the internal lay-out. this is a pic of the outside [img=left:22640f0c1d]http://i21.ebayimg.com/02/i/000/9f/f9/f334_1.JPG[/img:22640f0c1d]
Has anyone else had the same problem or does anybody know a solution to this issue?
Kind regards,
RD
Old 16th Jul 2007, 7:49 pm
Rassdesign , likely as you mentioned that the battery terminals are badly soldered to the player. Try opening it up and resolder the terminals back to the mainboard.
Old 16th Jul 2007, 7:55 pm
i just thought of the fact that i'd better wait till that guy replies about a settlement. However, i could demand another one lol, i'll give it some thought. But right now, it's irritating because i cant get it to power on anymore and use S1Clone by wire to back up my firmware and try finding an upgrade for it. Cuz i have a feeling that it might possibly have something to do with the firmware aswell, or can i rule that one out?
Greetz,
P.s i noticed you're from SA, loved being in Adelaide a couple months back! Great food
Cheerz!
badly need firmware PL24-3051-YD503-V2.0 Sharp Firmware 0 18th May 2009 7:10 pm
atj2091h firmware need ed badly:( suresh137 Firmware 5 20th Apr 2008 2:26 am
9.1.51 badly needed Diggins Dead Players 2 13th Jan 2008 6:37 am
i badly needed your help guyss.... blu_tear89 Video related 3 26th Jul 2007 7:36 am
Firmware badly needed MojoMan Dead Players 4 27th Oct 2006 1:20 am
