25th Jul 2007, 6:30 am
phaelon , it would be quite difficult to find such connectors. However, you can try your local electronics store and see if they do stock up on such connectors.
Another alternative would be to contact your seller for an exchange if it is still under warranty.
If the contact point is very small, you'll probably need a soldering iron with a fine tip. Usually those used for manual soldering of SMDs. These tips are inter-changeable.
