MP3 player with battery doesn't work, on USB is OK...
Old 25th Jul 2007, 2:04 am
Default MP3 player with battery doesn't work, on USB is OK...
hi... i have problem with ATJ2085 MP3 player...
like you can see in subject- it doasn't work with battery, but with USB is ok.. i have Ubat on board, e.g. 1,2V on pin 31 of ATJ..
it is simple mp3 player with external AAA bat...
no charger, and it is not problem in battery..
error is somewhere on board..
any idea ?
tnx...
Old 25th Jul 2007, 3:16 am
Have you opend up your player , You should check any loose wires ect... My guess is as good as yours- Provide some pics/more details...
Old 25th Jul 2007, 3:31 am
i have mocroscope in office and have search broken wires and so..
meas with instrument elements, 0e resistors, Ls, hole thru board.. didn't find anything..
will search a little more..
photos tomorrow - heven't camera here..
tnx..
Would a 3.7 V mAH Ipod Nano battery work in my nano clone? speedypear Support and How To 8 6th Mar 2007 8:32 pm
how to work my mp4 player dontwork Support and How To 1 13th Dec 2006 10:33 pm
How does the Mp3 Player utilities 4.00 work bugi Support and How To 3 29th Nov 2006 8:16 pm
[Solved] Will a 400mAH ipod nano battery fit & work t.powley General Discussion 4 28th Nov 2006 11:29 pm
Cannot get AMV files to work on my MP4 player mike Video related 34 1st Jun 2006 3:40 am
