Glacier Repair Toolkit - How to fix glacier player
Old 3rd Feb 2008, 11:19 am
Default Timer
When I turn on MP4 player it just gives me the Timer... I also can not connect to my computer..
Can you help?
Old 3rd Feb 2008, 11:24 am
Default Re: Glacier Repair Toolkit - How to fix glacier player
I get the blue timer at the start up and it will not go away..
Do you know how to fix this.
Old 26th Aug 2008, 5:35 pm
yes very good job friend
this is what i'm lookink for
thanx a lot
Old 16th Dec 2008, 12:36 am
Hi I'm trying to download the Glacier Repair Tool Kit - http://www.mympxplayer.org/glacier-r...evc-df621.html - but there is no link.
Can some one help me?
Old 16th Dec 2008, 1:51 am
On that page, click on the Click the image to open in full size. button towards the bottom of the page and you can download it then.
Hope that helps.
mp3 player repair and upgrade Toolkit download impn.net Support and How To 4 15th Jun 2008 1:13 pm
glacier type player Newfie_Chick Support and How To 5 26th Nov 2007 9:59 am
Does anyone have the Glacier 1GB mp4 player? graham01 Dead Players 1 5th Feb 2007 5:25 am
How about your Glacier player? Que General Discussion - Uxcell.com 35 1st Jan 2007 1:31 pm
How to put movies on my glacier mp4 player astrosarehott Support and How To 1 27th Dec 2006 5:58 pm
