Distorted Sound on 2Gb MP4 Player
Old 23rd Aug 2007, 2:46 am
Default Distorted Sound on 2Gb MP4 Player
Hi all, I need help please!
I have a Soundwave 2GB MP4 player which i have since found out is actually a MultiUnit MPF334.
The problem i have is that whenever i listen to music it sounds "wobbly" or as though you are underwater.
I have tried deleting the music and re-uploading it. I have tried reformatting to both FAT & FAT32. I have also tried 7 different headsets with no difference to quality of sound.
My son has exactly the same make and model and all of the music off mine plays perfectly on his - all headsets work as well.
I found the MultiTech website and visited it to see if there was a downloads section (there was but empty) or a trouble shooting guide (there wasn't). In fact the website is in my opinion a waste of bandwidth!
I go on holiday in a couple of days and would like to use my MP4. If i can't get it fixed then i'm gonna have to tell my son that HIS MP4 is broken but not to worry he can share mine - but that's not very paternal is it?
Thanks for reading this and any advice you can give.
Old 23rd Aug 2007, 4:30 am
i had the same problem with my sumvision kpac. heres what i did. took it apart, bent the two front pins inwards to make the earphone socket a tighter fit.
Old 23rd Aug 2007, 5:46 am
Default Re: Distorted Sound on 2Gb MP4 Player
Thanks man,
Tried that - didn't make any difference - must admit though, it was a bitch to take apart!!
Any other suggestions????
Old 23rd Aug 2007, 7:25 am
Skydoc , does it happen for every single file? What does it sound like when you tune into the FM radio instead?
Old 23rd Aug 2007, 10:30 am
It happens with every music track i put on - even the samples downloaded from this site. All the tracks play perfectly well on my sons MP4.
As far as FM goes...even though i have it tuned to exactly the same station as my sons, i can hear the radio perfectly on his but not a sound on mine.
do you think it might be a F/W issue?
Old 23rd Aug 2007, 10:38 am
If the player is new it might be a good idea to try and get a replacement
If you try and update the firmware it may kill the player, also It could be a hardware problem not a firmware problem
Old 23rd Aug 2007, 10:46 am
It's past it's warranty - my wife got it for me as a present and i've been abroad for quite a while so never actually did more than look at it and say thank you.
It's only the past couple of days that i actually decided to get it out of the box.
Never mind - i'll just have to cook dinner tonight and sweet talk her into buying me a new one!
Old 23rd Aug 2007, 10:55 am
If its unusable it might be worth trying to flash another firmware there are lots on this site, the hard part is finding the right one.
Need to start by looking at what version firmware it has in now and trying to find the closest match.
Old 23rd Aug 2007, 11:05 am
Ver:00.26.1845
Date:2006-12-25
Is that what you mean? That's what is says on the MP4.
On the disc it came with it has the following file:
0700C_1.79new_Soundwave_En_MLC.rfw
Do i need to use this file and how do "flash Firmware"?
I'm a complete noob at MP4's and stuff.
Old 23rd Aug 2007, 12:12 pm
Yes you've got a Rockchip player.
The file ending in .rfw is the firmware.
You have to install the ConsumerUpdate software from the cd on your computer.
Then load the firmware into ConsumerUpdate.
Go into update mode on your player via the settings menu and connect the usb cable,
Click the update button on ConsumerUpdate to flash the firmware and wait for it to complete successful before disconnecting the USB
You are lucky to get a firmware on your cd for this type of player.
If this works would you be kind enough to upload it for others to use on this site please?
AMV video problem: sound fine, picture distorted mamtoug Video related 1 20th Apr 2009 12:14 am
Audio is distorted through earphones, but ok through speaker geostar Support and How To 6 27th Feb 2007 12:18 pm
no sound in MP3/mp4 player please help dmittal74 Dead Players 1 4th Feb 2007 7:19 am
Distorted sound when full screen spacegv Video related 0 24th Nov 2006 1:55 am
Fonts distorted? tommelee Support and How To 5 25th Oct 2006 1:50 am
