Plugged into USB port and get a "Device Not Recognized&
Old 27th Aug 2007, 5:49 pm
Default Plugged into USB port and get a "Device Not Recognized&
I just got my player from uxcell, overall it looks like a great player, however the one issue i have is that when i plug it into my USB port i get a "Device Not Recognized" error. I have tried this on 2 separate computers with the same result. Any suggestions on how i can fix this issue? Is there a way to do a hard reset on the device or such to try to get this to be recognized in windows?
Old 27th Aug 2007, 6:13 pm
Default Re: Problem with Omega v88 player
I had the same problem. You have to setup the ConsumerUpdate tool from the installation CD that came with the player. If you you haven't already done so, do not upgrade your firmware because it will kill your speakers.
Old 27th Aug 2007, 10:19 pm
loki008,
Has it always happened or only just started recently?
What operating system are you plugging your player into?
Do you have a spare USB cable that you can try instead?
Old 28th Aug 2007, 10:30 am
Originally Posted by admin";p=&quot View Post
loki008,
I just bought the player and i have never plugged it in before. One thing i noticed is that when i plug it in it would show charging not the PC connect screen. After fiddling with it a bit what i found worked was when the player is off, if i plug it into the USB port it would turn on and it went to the PC connect screen. After i did this every time there after it has worked no problem on all 3 pcs i have tried it on.
Thanks for your help, this was quite an odd problem
Device Not Recognized - Need HELP! saiki Support and How To 0 19th Feb 2009 9:15 pm
device is not recognized lonemeto Support and How To 2 22nd Sep 2007 5:41 am
USB Device Not Recognized gyp_gyp Dead Players 4 13th Aug 2007 4:34 am
device not recognized carlagia Support and How To 3 21st Feb 2007 6:57 pm
Hi speed USB device is plugged into a low speed USB port nemrda Support and How To 1 17th Feb 2007 9:13 pm
