How do you replace the battery?
Old 29th Aug 2007, 7:45 pm
Default How do you replace the battery?
I'm pretty new here and I just wanted to know if there was anyway to change the battery of my mp4 player so It can play longer. I have no experience at all. Can someone help me?
Old 29th Aug 2007, 8:28 pm
Yes, it is possible to change the battery. You will need to find one the right voltage and size. Most MP players are 3.7 volt. You also have to take your player apart and find out how much space you have and how difficult the battery will be to remove.
I have changed the battery in an Icelander type player and the battery in a chipod. However, my other chipod the battery connections are soldered really close to the board. I wouldn't attempt that one.
The one I bought for the Icelander was a iPod nano battery. It's a tight fit but it works.
2 GB Black Temptation Player
8) WHITE MEIZU M6 8GB
8)
How to replace or fix a battery dimples78 Support and How To 3 5th Mar 2008 1:53 am
replace battery willyhehe92 General Discussion 35 5th Sep 2007 8:50 pm
Battery replace koschris Mods and Themes 1 25th Feb 2007 11:08 pm
replace battery wlazio2000 General Discussion 2 30th Dec 2006 10:50 pm
replace battery!!. nieuwe accu!!. Da_fixer General Discussion 0 3rd Sep 2006 1:24 pm
