Problems with Anyka Usb Nand Mp4 player
Hi
I bought a Anyka Usb Nand Mp4 player yesterday and the biggest problem with it is that when i press the Forward button in the media player it doesn't skip to next song and instead it opens the music playlist to choose songs from (which is weird coz every mp3 player has this option that if u press the fwd button once it changes the song) Any remedy for this? probably a software upgrade or anything because im using this player in my car and i cant look at the playlist everytime to change the song Any help will be appreciated..u can also reply me at pmurtz83@yahoo.com |
DON'T upgrade your player there is a 99.999999999% chance of bricking it. do you have a pic of ur player.
Go to the explorer and choose a song or a folder for the example and push to menu botton and choose "add to playlist" and there you go man..DON'T NEED TO UPDATE FIRMWARE BEWARE OF IT!!!!! DON'T BE A FOUL!!!
| All times are GMT -7. The time now is 5:37 pm. |
