-   -   Recharge problem (http://mympx.org/forum/support-how/38916-recharge-problem.html)
blackknife 5th Sep 2007 2:28 am
Recharge problem
I recharged my 8 gb (4 real) nano clone two times for about two hours but after 1,5 hours it says that the battery is finished....
What can i do?
lattesurf 5th Sep 2007 2:45 am
blackknife , how did you charge your player? If it was via USB, i'll suggest charging for a longer time (about 3-4hours). Then test the full play time of your player again.
blackknife 5th Sep 2007 3:45 am
Re: Recharge problem
I also tried to leave it in charge whit the ac adapter for all the night but nothing to do..
lattesurf 5th Sep 2007 6:48 am
blackknife , have you set your player to auto off its screen after a few seconds of idling? This would greatly improve the playback time.
blackknife 5th Sep 2007 12:04 pm
obviously i did...
lattesurf 5th Sep 2007 4:40 pm
blackknife , then your battery probably does not hold its charge very well. Typical players usually have a play time of about at least 3-4hours per full charge.
blackknife 6th Sep 2007 5:03 am
Is possible to change the battery on a mp4 nano clone like this :
http://img440.imageshack.us/my.php?i...2007175vy9.jpg
If yes there's a battery that has a play time of about 10 hours?
(the original ipod battery has a play time of about 24 hrs)
blackknife 6th Sep 2007 5:28 am
I was thinking about changing the battery whit an original ipod nano one.
is it possible?
lattesurf 6th Sep 2007 7:13 am
blackknife , it all depends on whether your current player has enough space allowed for the battery replacement.
You'll need to open up the player and measure the maximum allowed space for the battery. Then ensure that the replacement battery is either same or smaller than the measured size.
Usually with a good battery replacement, you'll probably end with perhaps 5-6hours of music playback time. It is not possible to get 10hours without any external battery pack.
