Need help with DIY MintyBoost charger
Old 7th Sep 2007, 3:39 am
Default Need help with DIY MintyBoost charger
http://www.ladyada.net/make/mintyboost/index.html
This website shows you how to make a travel charger for yourself, that uses 2 AA batteries as a source.
Can an expert here tell us if that charger will work safely with a 2gen. Nano MP4 (Full metal platinum... whatever)? Is it's power output right for this player? How do I know what power does my player use?
Any help is aprechiated.
Thanks.
Old 7th Sep 2007, 3:58 am
di48lo , generally all nano clones are able to be charged by such DIY chargers. They just simply need a 5V power supply.
I've seen this DIY charger sometime ago, and is by far one of the best designed and efficient DIY chargers using the boost converter.
Happy DIY-ing.
Old 8th Sep 2007, 3:48 am
Default Re: Need help with DIY MintyBoost charger
Always ensure to run such switching power supply inside a shielding enclosure as indicated above, since they produce large amounts of interference.
Old 8th Sep 2007, 7:43 pm
I would not want to pay 19.50 US dollars for a tin can, and have to go to the trouble of making it. ops:
you should consider buying one of these? for 14 US dollars which is about 7.20 pounds sterling.
Take a look for yourself ? and I'm as happy as Larry with mine :P
My Power Backup came, in just over a week from Hong Kong.
Good price for around £7.20 from http://www.dealextreme.com/details.dx/sku.3060 and works very well indeed.
So if some of you guys want extra battery power on the move.
Then I would recommend buying one of these, just a good as the Power Monkey, but a lot less in cost. The power monkey sells in the UK for around £29.00, and around £26.00 on E Bay.
Edit
Forgot to mention that I paid by Pay Pal which made it easy
:idea: I Can''''t wait to get my teeth into the mother of all mp3 players. THE M8 :P
Old 11th Sep 2007, 9:55 am
The Power Backup seems a good choice. But since I live in a country which is banned from PayPal, it's easyer for me to build a MintyBoost than to buy somethin online.
BTW, I will buy every part in a store.
MP3 Charger mekako Support and How To 8 23rd Jul 2007 11:50 am
About Li-ion battery and charger VitaminM General Discussion 0 28th Jan 2007 12:33 pm
IClone Charger daniel50 Support and How To 2 21st Jul 2006 4:43 am
Charger adaptor pepe Support and How To 3 27th Jun 2006 9:04 am
wall charger guest Support and How To 0 17th May 2006 4:26 pm
