ipod nano clone 9.0.50 problem!!!!!
Old 8th Sep 2007, 8:08 pm
Default ipod nano clone 9.0.50 problem!!!!!
hi ıam new here i have ipod nano clone firmware verison is act_s72_ 9.0.50 but i cant update it to 9.060 because i tryd it with atj uploader but not gone which uplloader can do it or how the 2. problem i want to modify my ipod which program is to modfy 9.050 and where can i find the 9.50 modify and theme files pls pls help msn:thatsmydream@hotmail.com İ NEED REAL HELP ABOUT İT
Old 8th Sep 2007, 8:25 pm
kreuzberg , v9.0.50 is currently not supported by any firmware extraction tool as yet. Without the extracted firmware, it is not safe to download someone else's themed firmware to flash into your player. As it would very likely brick your player instead.
i'll suggest that you leave your player as it is until the tools are available.
Old 13th Sep 2007, 4:10 pm
Default Re: ipod nano clone 9.0.50 problem!!!!!
I have the exact same problem. are they making software for the 9.0.50 firmware?? i am despret!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
Old 13th Sep 2007, 5:22 pm
csteinmetz1 , new tools for the v9.0.xx firmwares are underway, but progress is slow. However, when it is available, you'll find it here.
Old 14th Sep 2007, 11:20 am
Thanks for the info. i bought a new 1.5 inch ipod clone from ebay. i don't know what type of firmware it has i have a link to the picture below. Also is there a way to change the type of firmware on my player. PLZ help
Old 14th Sep 2007, 11:21 am
Thanks for the info. i bought a new 1.5 inch ipod clone from ebay. i don't know what type of firmware it has i have a link to the picture below. Also is there a way to change the firmware completlyClick the image to open in full size.
Old 14th Sep 2007, 5:02 pm
csteinmetz1 , it is not possible to identify the firmware version from the picture or ad description. You'll need to navigate to the Firmware Version option in the System/Settings menu. There, it will list the installed firmware version.
However, seems that this seller sells hacked players. http://toolhaus.org/cgi-bin/negs?Use...ed+by&ref=home
There are many negative feedbacks that the player is a hacked 2GB.
Old 14th Sep 2007, 5:44 pm
If it is hacked is their a way to fix it.
Old 14th Sep 2007, 6:00 pm
csteinmetz1 , no. If it is a 2GB chip hacked to show 4GB, you will only have 2GB in the end.
There is no way to make the 4GB reappear unless you hack it again. Besides, a hacked chip would only gradually cause your player to fail after some time.
3rd Gen Ipod Nano Clone Problem! XDude Dead Players 22 12th Mar 2009 2:49 am
Problem with mp4 'ipod nano clone type' player jazf2008 Support and How To 0 10th Mar 2008 11:08 pm
Problem with my 1gb s1mp3 (mp4) like nano ipod Ramsus Firmware 0 10th Feb 2008 11:53 pm
I have a problem with my Fake nano Ipod Stone Fist Support and How To 4 5th Oct 2007 12:26 am
Would a 3.7 V mAH Ipod Nano battery work in my nano clone? speedypear Support and How To 8 6th Mar 2007 8:32 pm
