-   -   Headphone Jack Problem (http://mympx.org/forum/support-how/38980-headphone-jack-problem.html)
nem15 10th Sep 2007 5:32 pm
I just got my mp3/4 player from dealextreme.com and everything is fine but when i plug my headphones in the jack, the music starts to lag like mad... when i play off the speaker its fine... is there any way to fix this?
http://www.dealextreme.com/details.dx/sku.5657
thats the mp3/4 player
lattesurf 10th Sep 2007 5:45 pm
nem15 , does it happen constantly with the earphone for all files?
It seems to be some hardware related issues.
nem15 10th Sep 2007 5:55 pm
it happens constantly, every file ive tryed, in all different settings
lattesurf 10th Sep 2007 9:06 pm
nem15 , it is likely a hardware problem as the speaker is able play them properly but not the earphones. Probably some components in the earphone circuit is damaged.
Besides, trying to fix by flashing another firmware would likely kill your player. i'll suggest you contact the seller, and probably get an exchange.
nem15 11th Sep 2007 1:36 pm
thanks alot, ill contact them right away
