Not sure what to upload from MP4 driver/firmware CD.
Old 12th Sep 2007, 2:32 pm
Default Not sure what to upload from MP4 driver/firmware CD.
Just got a MP4 player from Computer Geeks. (This player: FHM-010-A) The driver CD which came with it appears to have utilities and a firware restore utility but the documentation on the CD is all in Chinese which I don't read so I can't be 100% sure. The file structure of the CD is:
Code:
|-- SMV convert tools
|   `-- SMV Video Converter Tool.msi
`-- driver
    |-- Apps
    |   |-- Thumbs.db
    |   |-- regdll.dll
    |   |-- stmpres.dll
    |   |-- stunicow.dll
    |   |-- stupdaterapp.exe
    |   |-- uninstall.ico
    |   `-- w98eject.exe
    |-- Binary
    |   |-- bootmanager.sb
    |   |-- hostlink.sb
    |   |-- hostrsc.bin
    |   |-- resource.bin
    |   |-- stmpsys.sb
    |   `-- updater.sb
    |-- Drivers
    |   |-- StMp3Rec.sys
    |   |-- StUmsPdr.cat
    |   |-- StUmsPdr.pdr
    |   |-- Stums.cat
    |   |-- Stums.sys
    |   |-- stmp3rec.inf
    |   |-- stmp3recnt.cat
    |   `-- stums.inf
    |-- ReadMe.doc
    |-- Thumbs.db
    |-- data1.cab
    |-- data1.hdr
    |-- data2.cab
    |-- engine32.cab
    |-- layout.bin
    |-- setup.boot
    |-- setup.exe
    |-- setup.ini
    |-- setup.inx
    `-- setup.skin
5 directories, 35 files
I'm guessing the files under the driver/Binary subdirectory are the firmware images. This appears to be a SigmaTel based player. Anyone know for sure what I should upload? Thanks.
Old 12th Sep 2007, 4:59 pm
techt , you should not flash the player with the firmware. Chances are you'll likely brick it. Use the firmware file only for recovery purpose, or unless you feel adventurous and willing to risk it.
Upload de Firmware alexbrx Dead Players 2 13th Jul 2009 5:29 pm
How to upload a firmware? over General Discussion 4 8th Dec 2008 11:35 pm
Can't upload firmware I want Andy_Vendetta Support and How To 1 14th Jun 2008 7:26 pm
Can't upload firmware ZShock Dead Players 1 5th Jun 2008 8:07 am
why upload firmware mario milas Dead Players 0 22nd Jan 2007 9:31 am
