My MP4 player works fine, but certain things dont work! HELP
:!: I got my 2 GB mp4 player in the mail last week from eBay, and it is better than described, but some problems are present.
For one thing, it dumps all its memory every once in a while, saying "disk error!" when I try to access them, meaning that I have to format it (FAT) every once in a while. Second, When I try to play the games it comes with, THE DOWN KEY DOES NOT WORK! YOU CANT PLAY MINESWEEPER WITHOUT A DOWN KEY!!! :P :lol: :shock: I DONT KNOW WHAT TO DO!!! I LOVE THE PLAYER BUT WANT TO USE IT PROPERLY! HELP! :( This is it: http://cgi.ebay.ca/GM2V-NEW-1-8-2G-2...QQcmdZViewItem ( it doesn't really say ePro at the back, because this is a clone, but workr really well.) |
George Samuel , try a format with MP3 Utilities Disk Tools to verify the actual capacity first, guide here http://www.mympxplayer.org/how-to-re...ck-vt2400.html
Check for the installed firmware version number. You can do so by going to the System/Settings menu, then selecting Firmware Version. What does it say there? It seems that seller has quite a number of neutral and negative feedbacks http://toolhaus.org/cgi-bin/negs?Use...ed+by&ref=home Having 98.2% for a feedback score of 14845 doesn't look good at all. |
Re: My MP4 player works fine, but certain things dont work!
I verified the memory capacity at 1.89 gigabytes, and the firmware version says:
LSC_91N110_10 2007-05-05 V9.0.50 2005-01-09 Thanks for replying I really appreciate your help! |
Hi George
You can rest asured...your item was not hacked..LUCK YOU! BTW, I sawyourmpx...quiet interesting....if the selleris goodone..good forhim..we can add him tothe WHITELIST then... Hopeyouresolve the issues about it...atleastitsnot hackedatall...onelessthing toworry about and higher chances toenjoy yourmpxonly. Thanks(AM searching for the mpx tobuy from a decent seller.Id bought several hacked mpx from different sellers and websites.). |
| All times are GMT -7. The time now is 5:12 am. |
