Problems with buttons
Old 2nd Oct 2007, 12:29 am
Default Problems with buttons
I'm sorry if this is in the wrong section, but I'm not sure if firmware is my problem since I have never updated it or even touched it.
When I first bought my 1gb iPod nano lookalike mp4, the buttons worked perfectly, but now the function of the buttons always seem to change. For example:
Sometimes all of the buttons (except 'play') act as the Menu button and I can't select any songs or different menu options.
Sometimes all the buttons seem to work perfectly. I don't know what the problem is and I've only had it for about a month. If you need to know the firmware (just in case that is the problem), I will write it down when my player's buttons are working correctly.
I'm too scared to take apart my player and see if the hardware is a problem, but I will try that as a last resort if I have to.
Thanks for any help you can give me.
Old 13th Oct 2007, 3:19 am
Default Re: Problems with buttons
i tried uplouding firmwae and got dead mp4 player
Old 3rd Jan 2008, 2:05 am
random0guy,
Try FORMATTING your player to see if that helps.
Let me know.
Old 3rd Jan 2008, 8:47 am
i recommend a format with mp3 utilities if your player is ACTIONS player...
u maybe also can do a full format with windows...perform full format not quick format
waiting for exam results.
Old 6th Jan 2008, 2:54 pm
I have a 2GB clone running firmware 9.1.53 and I have the same problem. I tried reformatting through Windows to no avail. The supplied utilities refused to format the drive.
Any other ideas?
Old 6th Jan 2008, 8:26 pm
Any other ideas?
Hi foboz,
Can you create a new thread for your question please? Your question is different from the original post in this thread so it would be great to keep it seperate.
Buttons not working :[ Andyyy Support and How To 6 19th Mar 2007 7:09 pm
Non responsive buttons Qreg Support and How To 2 1st Jan 2007 3:38 pm
Buttons doesn't want to work.. someguy Support and How To 0 8th Oct 2006 9:03 am
Buttons not working Korona Support and How To 1 14th Sep 2006 8:20 pm
I have Broken buttons hank27 Dead Players 1 22nd Jul 2006 6:59 pm
