Battery Consumption on MP4 Player
Old 6th Oct 2007, 9:03 am
Default Battery Consumption on MP4 Player
Hi,
I got an almost new MP4 player Ipod nano clone 9.0.50 running on ATJ2091.
The battery works for about only 1h, 1h and half... then it's at 0...
it doesn't seem normal... any idea/solution?
I also don't understand what elds on my charger means... sometimes there are two leds, one green and one red on, sometimes only one of them... and the player is still charging in both situations...
Old 6th Oct 2007, 11:29 am
Dr. Fix, up to 90 minutes is not much to enjoy your music. It should be more, normal is 3-4 hours. Make shure that the player is turned on by the main switch on top of the player when you charge the battery
Old 7th Oct 2007, 1:11 am
Dr.Fix , also you might want to set the screen to auto turn off after about 5-10seconds of idle time (eg during music playback). This greatly saves alot of battery power.
Old 7th Oct 2007, 2:46 am
Of course I do it or it doesn't charge at all...
That's the first thing I did when I turned it on for the first time
WTF stupid player!
Old 7th Oct 2007, 3:55 am
Dr.Fix , if that's the case, then likely your battery doesn't hold its charge very well. It is a common problem as the manufacturers do not exactly use the best quality batteries. A solution would be to manually replace the battery in your player.
Battery on player doesn't last long enough panagath Support and How To 3 14th Jan 2009 1:15 am
MP3 player with battery doesn't work, on USB is OK... zaks Support and How To 2 25th Jul 2007 3:31 am
Find a battery that will fit into this player bleakill Support and How To 11 30th May 2007 6:19 am
Need Battery for Rhodium Player vikki99 General Discussion - Uxcell.com 2 23rd Nov 2006 7:39 pm
low battery in my 2 gb mp4 player torn22 Support and How To 3 7th Sep 2006 3:15 pm
