Sound is hacking and sometimes delayed like an echo...help!
Old 8th Oct 2007, 3:46 am
Default Sound is hacking and sometimes delayed like an echo...help!
When I convert to AMV in 128*128 solution the sound works fine but as soon as I choose 160*120 the sound goes bad...like an echo. My screen is 1.8" so it suppose to fit. I´ve been trying with all kind of versions and even modded versions but the problem will not disappear. I have installed all the codec i need (I think). I have also installed PocketDivXEncoder_0.3.60 without solution. Does anyone know what teh problem is?...
thx!
Old 8th Oct 2007, 3:08 pm
Default Re: Sound is hacking and sometimes delayed like an echo...he
thx!
Install the K-Lite Mega Codec Pack, you may have a broken/outdated codec...
Old 8th Oct 2007, 10:02 pm
Well....I´ve already got that installed but not the latest though. But I´m gonna update my K-Lite and see what happens.....
Old 9th Oct 2007, 11:12 am
I have updated my K-Lite to latest version but.....its still same shit...just a different day!
Old 9th Oct 2007, 12:07 pm
Maybe you have a bad configuration in a sound filter (like ffdaudio)... It's the only thing I can think of...
Old 9th Oct 2007, 10:10 pm
usually got the prob coz..codec.. i use k-lite
waiting for exam results.
PROBLEM TO REMOVE AN MP4 hacking dj_chiquito Support and How To 19 27th Apr 2011 11:52 pm
De-Hacking Method would not work caLVin Support and How To 11 7th Sep 2008 10:11 pm
Delayed audio? Lehmo Video related 1 29th Feb 2008 6:14 am
sound jtaiariol Support and How To 6 28th Nov 2006 6:33 pm
Echo in amv files? Video related 9 2nd Jun 2006 1:02 pm
