-   -   Firmware problems for Onda vx858 , also lookin 4 vista skins (http://mympx.org/forum/support-how/39389-firmware-problems-onda-vx858-also-lookin-4-vista-skins.html)
snowfruit 21st Dec 2007 4:34 am
Thanks knob - i wasn't aware that an extractor was in the works. I'll wait for that to be completed.
CoreyHdawg 4th Jan 2008 3:34 pm
Firmware problems
hey DaremoS
hello i have just read the follwoing page and i have a onda VX858LE and also have the english language but some parts of the player are still in chinese such as when i try the firmware update all i see is chinese around do not enter and would like a full explanstion of how in a safe way with links to the latest version of firmware for my LE model to ugrade my firmware so that my player is in fully english and with new skins etc. and also any other inforamtion if i need to install anyy reliivent rivers fro my player.
thank you. my regards :)
kevinjkok 12th Jan 2008 6:03 am
Re: Firmware problems for Onda vx858 , also lookin 4 vista s
Originally Posted by DaremoS";p=&quot (Post 40795)
Originally Posted by Ridion";p=&quot (Post 40781)
I tried installing the vista firmware on my vx585 equivolent and it appears bricked.... the touch screen is irresponsive so i can't get into the settings menu to get firmware upgrade.... someone help?
This aren't good news... if it's showing initial screen but touchpad not responding... was chosen bad firmware this way: if you installed VX858LE then your device is VX858 non LE and vice versa.
Try as much as you can pressing menu while you plug USB cable.
If this not work... open device and short-circuit flash memory pins with USB cable connected. This always work!... just be calm and do thing with no hurry. Device must be opened by nails or you will damage case.
Locate carefully flash memory, normally a Samsung chip... with USB cable connected run the rounded side of a clip along pins until your hear the sound of your PC announcing connection. This will put your device in "rockusb" mode... then you can reinstall the firmware this time choosing a LE or nonLE, different to the one you install first... don't pay attention to version V2 V2 it doesn't matter for the moment.
Search here for more information of "hardware method" if you don't feel sure.
"dead" OEM VX858 player after installing firmware 000.017
After installing this my MP4 didn't react any more and i got it on with those clips and so on. Everything works fine until i want to install the correct firmware with ConsumerUpdate. Almost immediately it tells me that the usb device is not found. The device is present in My Computer. Can anybody please help me??
I bought this one from Hong Kong from e-bayseller2008:
Brand New 2.8" QVGA Touch Screen
4GB MP3 / MP4 Player using Flash Memory 2.8"LCD
Touch Screen
support MEMORY CARD
New Elegant Design
100% Brand New in Color Black
Interface : 2.8" TFT interface
Display : 320 x 240 dot matrix 260K True Color Display
Built-in Memory : 4GB Samsung Flash Memory
Supported up to 4GB Mini SD Card expansion
Size : 95 x 56 x 14 mm
Weight : 95g
Picture Browsing JPEG, GIF, BMP formats
2GB Photo Capacity Around 2000 photos (2.0MB file size)
2GB Song Capacity up to 2000 songs (128kbps)
2GB Video Capacity up to 10 hours
Voice Recording with built-in microphone
Audio Support MP2, WMA, etc....
Video Support MPEG-4 (AVI)
FM Recording : Built-in FM / FM Tuner Recording
Voice Recording : Built-in Mic
FM Radio with 8 preset channels
Connectivity: High-Speed USB 2.0
Support OS : Window 98/ME/2000/XP
Battery Type: Built-in 2000 mAh rechargeable Lithium Battery, Support up to 8 Hours Video & 16 Hours Audio Playback
Specification
Carry Music, Video, Photos and Files wherever you go
Brand new touch screen operating system makes navigation a breeze
Record voice and more with built-in microphone
Record your favorite music directly from FM radio
8 Equalizer Setting : Jazz, Classic, Pop, Rock, Natural, 3D, Bass and Custom
Multi-Tasking: Play MP3 and Read eBook at the same time
Multi-Language : English, France, Spanish, Deutsch, Italian, Portuguese, Japanese, Korean
CHIPSET : ROCKCHIP / RK2608A
Dynomo 13th Jan 2008 5:39 am
kevinjkok, did your player come in orange box? If so I have the firmware for this player to hand as I have the same player and updated my firmware fine. Mine came from same Ebayer seller. If yours is in orange box you have a clone vx858le, not made by Onda. If you installed Onda firmware then it will kill your player. But you should be able to recover it.
ondaclone 10th Mar 2008 9:38 pm
firmware update
I have clone VX858 i bought from ebay. i just upgraded to the (firmware 000.017) and it works great with the new oem onda startup and off screen. is there a way u can play music while ur viewing ur pic ???
ondaclone 12th Mar 2008 8:50 am
Hi, on my last post i said i upgraded to firmware (00.00.0017). my mistake, it was firmware (00.00.0020). works great with onda slash startup and off screen. this firmware is for clone vx858 with rockchip. anyone wants the consumer and firmware let me know.
matuka 12th Mar 2008 9:05 am
I need it but my clone have camera,
ondaclone 12th Mar 2008 7:54 pm
Hey Matuka, this firmware will brick ur player. look in other posts, for the correct firmware.
todd79 29th Mar 2008 5:07 pm
wow
Hi I have just bought a vx858 on ebay, and after reading all this wish i didnt! How do I know if its a clone, What does bricking mean and why does the firmware (which i also don't know about) need to be updated???
Im so glad ive found this site any any help will be much appreciated! Im in Australia.
Todd
