Chargin Mp4 player Problem?
Old 22nd Oct 2007, 5:37 am
Default Chargin Mp4 player Problem?
hi i have the following mp4 player from ebay....
4GB 1.8" LCD USB 2.0 Drive PMP FM MP4 MP3 Player RSS4
i got a replacement today as i bricked my other one and the guy sent me a replacement one...
i managed to check the firmware on it was 9.0.52 , previous one was 9.0.50...
however it seemed to be working fine and i havent updated the firmware or nothing but as it was chargin via the usb, the pc lost connection with the mp4 player.
i left it off for around 20minutes and tried switching it on. It loaded up with a blue screen and a hour glass. it got to the menu then the low battery logo comes up and it switches off. So i guess it needs chargin via usb, so wen i do plug in the usb and switch the player on the pc does not detect the player and it does not charge all i see is the blue screen and the hourglass and it flashes on and off..
i dont think it is bricked cus if i leave the player long enuff for half n hr unplugged den switch it on it does come on and go to menu but cus the battery is low it doesnt stay on for long.
ne ideas?
quick note: Mp3 player utilities software i tried that and it cud not detect it....also i noticed before it turned of that the battery bar was empty.. how long does a charge usually take? via usb? i also got a V3 motorola charger and that uses the same connector and outputs 5v. could i use that?
Old 22nd Oct 2007, 7:35 am
Default Re: Chargin Mp4 player Problem?
i guess ill wait a few hrs n see if it does charge? how long does it normally take the manual said ne where between 3-6hrs via usb...
Old 22nd Oct 2007, 12:15 pm
no luck.. the hour glass screen with a blue background just keeps flashing on and off and then after a while i only see a black screen?
im stumped!(?)
Old 22nd Oct 2007, 9:11 pm
aznkix , likely the firmware is corrupted due to a memory hack. This seller has quite a number of negative feedbacks about selling hacked 8GB memory sticks. So i won't be surprised that your "4GB" was hacked too. Considering a 2GB chip costs about USD$28, and you paid about USD$37 for your player, it is extremely likely it is hacked, perhaps only a real 1GB.
i'll suggest that you get a full refund from your seller. As there are no known v9.0.50 firmware extraction tools at the moment, you'll probably be unable to recover your player.
Problem with new MP4 Player deepakrr General Discussion 3 6th Jan 2007 10:27 am
problem with my mp4 player. lordik Support and How To 1 6th Oct 2006 3:26 am
my mp4 player 2gb problem BONESZ Mods and Themes 2 8th Aug 2006 4:40 am
My mp3 player problem Jeans Support and How To 1 7th May 2006 9:15 pm
