MP4 cam 2.4lcd device not found
Old 27th Oct 2007, 7:49 pm
Default MP4 cam 2.4lcd device not found
it came with a cd with a app name "MP3 Player Upgrade Tool" but it keeps saying "device not found" and i look through the menu and i cant seem to find a update option help me please i want to chance this lame theme it came with
Software: USE_Monolith_2kV0.0.12
HardwareVT2.1
Audio: V0.5.29bch2
1GB,1.3mp cam,speaker
[this is the picture viewer displaying the WinXp boot picture]
Old 27th Oct 2007, 9:07 pm
smbhtid , it does not appear to be Actions based, which MP3 Utilities only works.
It is likely your player is a Sunplus chipset due to the Camera function.
Old 28th Oct 2007, 9:49 am
I try extracting the files with "s1fwx.exe" but it saids device not found
and I don't know what to do now
Old 28th Oct 2007, 10:44 pm
smbhtid , S1fwx only supports the Actions chipset. As your player would likely be using the Sunplus chipset, it is not able to extract the firmware.
If your player is working proplery, i'll suggest that you do not do anything to the firmware.
Old 28th Oct 2007, 10:46 pm
ok thanks
Black Screen - Dead - Nano clone - USB device found but no dezigntek Dead Players 12 6th Jun 2008 1:52 am
Device switching failed, reconnect device please rakashmiri Support and How To 10 29th Dec 2006 7:25 am
device not found erviins General Discussion 2 13th Sep 2006 1:16 pm
[solved] Device Switching Failed, reconnect device please! Spawn_20240 General Discussion 5 2nd Aug 2006 6:44 pm
MP4 Player shows as 'USB DEVICE' not 'ADFU SERVER DEVICE' gregthomas02 Dead Players 5 18th Jun 2006 4:56 pm
