6th Nov 2007, 11:13 am
Originally Posted by alex2pb
No, this is not good in my opinion. There's something wrong with the battery, maybe they are old. The best way is to let it charge as much as you can, because at some players, the battery indicator is broken and does not reflect the real charging process. Remember to turn the player on before charging. If this fails, you should contact your seller for a replacement or a refund.
Alex2pb or boonkang
I am not sure who will receive this reply, but will do as you both suggested.
First recharge through the PC, if that fails I will make contact with whom I purchased from (unfortunately through eBay) but I will give it a go and see if they will replace
I was hoping that I could just replace the battery, but it appears that is not possible
Thanks again
Gloria
