Poor sound quality
View Poll Results: How would you classify the sound quality of your player?
Good (like CD or better) 0 0%
Normal (like good radio) 0 0%
Bad (like K7 or worst) 0 0%
Voters: 0. You may not vote on this poll
Old 9th Nov 2007, 4:43 pm
Default Poor sound quality
Hi,
I bought a me2 player on ebay. It turned out to be a me2 clone, and instead of 4GB, it was only 2GB. After formatting the player to get the correct memory capacity, I noticed that the sound quality is poor: there's a lot of noise in background, just like it used to be with k7 players. I have tried good earpiece, so it must be the player. Anybody has this problem to? Is there a solution (beside buying a new player)?
Old 10th Nov 2007, 2:47 pm
mine does that to but i think its becuse the meant to do that
Honestly what do you think of Chi-Pod & sound quality? abombaci General Discussion 5 15th Jun 2009 5:58 am
VERY bad sound quality kidcasino Support and How To 3 1st Feb 2009 6:48 pm
mp4 ipod dock with poor sound quality scott-ayling Support and How To 2 25th Nov 2008 11:50 pm
Glacier sound quality kamoon General Discussion - Uxcell.com 6 25th Jan 2008 7:23 pm
Can we adjust the sound quality of AMV files? hongkie3 General Discussion 2 19th Jul 2006 2:20 am
