Problem in fake iPOD
I just borrow his fake iPOD... then when i right click it on the computer its 800mb+ but when i double click the icon, no files..
Then when i tried copy it to iPOD fake.. it cannot be copy o even make a Folder! Then i knew there was still movies and music files in it but when i play the fake iPOD... the screen says "Empty Disk".. same goes when i play video. but im sure 100% theres a file in there... this thing start hapenning when i copying my music files into the fake iPOD then it runs out of battery.. then when i play it.. it start saying "Empty Disk" i record my firmversion... im a newbie. here it is. 2007/02/14 9.1.51 2007/06/01 CTW 600 I dont know WTH meaning with that.. but im so eager to fix my mistake. T_T |
Endless , i'll suggest that you format the player with MP3 Utilities Disk Tools, guide here http://www.mympxplayer.org/how-to-re...ck-vt2400.html
It is likely that a memory hack or memory corruption caused the error message. |
Thnx.. but how can i recover the files inside?
Endless , access the player via its removable drive and retrieve the files out. However, if you can't access the removable drive, likely the memory chip has been corrupted and needs a format. Which means the previous files in it would be erased as well.
ok.. thnx for the info.. my player now run smoothly. ^_^
| All times are GMT -7. The time now is 1:35 pm. |
