Skinning my MP4 using firmware 9.1.52 i found on net
Old 13th Dec 2007, 11:36 am
Default Skinning my MP4 using firmware 9.1.52 i found on net
Lets get things straight here.
I have purchased a LG MP3 player B8201 CM70048 ACT_V9.1.52 MP4
And I would love to get rid of the stupid chinese like skin.
I think I could even manage to make my own theme. Only problem is to extract the original firmware.
As there doesn't seem to be a method to extract a 9.1.52 fw i went searching and found this chinese site.
After help of our great friend Google (translator) i guess i found the exact same firmware. At least it shows the exact same images as on my MP4.
So I could eventually start testing my modding skills. Only problem is, viewing inside s1res.exe is pretty difficult. Is there another way of seeing my skin (working) before actually7 writing it to my player?
And how great would chance be that i kill my player allthough images look exact same?
Or is there anyone out there who wants to take the job of producing a nice ipod skin like this adapted to this player.
Firmware is available here
"If you really want something in this life, you have to work for it. Now, quiet! They''re about to announce the lottery numbers..." - Homer Simpson
Old 13th Dec 2007, 11:57 am
Default Re: Skinning my MP4 using firmware 9.1.52 i found on net
Welcome screen looks like this, so you know which fw i am talking about .
Old 13th Dec 2007, 4:13 pm
99% chance to kill player
these images are standard in these firmwares and can be used in any, so DO NOT RELY on image to find correct firmware.
there is pretty much no chance you will find the firmware unless you contact supplier and ask - picking a firmware based on like images is a SURE way to brick your player
do this at your peril !!!!!!!!!!!!!!!!!!!!
Old 13th Dec 2007, 10:37 pm
Of course it wasn't only the images. The site shows pictures of the same (99%) player (nano II clone) and the fw version seems to fit. Even the hardware version number is correct (8201 in my case)
And am I correct that there is currently no way to extract my own firmware ?
And what about my other question, any way of seeing my modded fw in action before actually writing it to player (just want to play with the skinning part).
If sooner or later an original extraction can be made i guess the images are the same as long as pixel size correct, so images could already be prepared... (even though i am not going to try i'm pretty sure it's the fw related to my player)
A firmware request - nowhere to be found Groovy Firmware 0 1st Feb 2009 4:56 am
Modding & Skinning OndaVX858 Clon matuka Mods and Themes 0 5th Mar 2008 1:05 pm
Skinning Onda VX858LE Dancemammal Mods and Themes 44 5th Mar 2008 8:10 am
Skinning my clone - Hard to know which to replace? MrSix Support and How To 0 15th Jul 2006 12:54 am
Toprid MP4 Main menu skinning^^ Mods and Themes 7 2nd May 2006 11:26 am
