Problems with 1GB iPod Shuffle Clone Clip MP3 Player
Old 18th Dec 2007, 2:14 pm
Default Problems with 1GB iPod Shuffle Clone Clip MP3 Player
I have a new 1GB Clip MP3 Player which is pretty much an iPod Shuffle Gen 2 Clone.
It currently has used 560MB and has 415MB free, so the total capacity is 975MB.
When I try to add new music it shows this error:
P.S I made the file called song if anyone was wondering..
It is only 1GB so I doubt it's a hacked player, is there anything I can do to try and fix this problem so I can put more music onto it?
Oh, it is currently formatted in FAT.
If anyone can help me I would really appreciate it. 8)
Old 19th Dec 2007, 1:59 am
Default Re: Problems with 1GB iPod Shuffle Clone Clip MP3 Player
Hi nzer_4_lyf,
How many songs do you have currently in the root of the player?
Try putting them into folders then add your new songs and see if that works. I know some players have a limit of 99 files in one folder (ie: root of the player) and it won't allow more.
Otherwise try formatting your player to see if that helps.
Old 19th Dec 2007, 11:55 am
Hi admin
It currently has 128 songs in the root directory.
When I try to make a new folder it says this:
What file system should the player be formatted in; FAT or FAT32?
Should I format it via My Computer or via MP3 Player Utilities?
I deleted 1 song from it then I was able to transfer one new song, it seems it has a limit to 128 songs which is really annoying!
Old 19th Dec 2007, 12:16 pm
Ok, so I deleted some songs from it then made a new folder, guess what, it now has 665MB of music.
I haven't tested it yet though but since it has no screen will it work with directories?
Thanks for your help so far admin!
Need firmware for Shuffle clip clone 1GB Phili123 Dead Players 3 19th Jan 2010 9:21 am
Big Lots $15 Sylvania 2gb IPod Shuffle clone yanose22 General Discussion 0 7th Sep 2009 2:41 pm
ipod shuffle clone won't turn on and says no disk RodAlvenis Support and How To 0 18th Feb 2009 5:48 pm
ipod shuffle clone serious problem technologue Dead Players 10 17th Sep 2007 7:12 am
Instructions for iPod 2nd Generation Shuffle clone? RowMan Support and How To 5 1st Jun 2007 12:34 am
