Not allowing me to adjust exposure/brightness
Old 19th Dec 2007, 11:08 am
Default Not allowing me to adjust exposure/brightness
Hello guys ,
I have purchased a Mpeg4 player.I have a problem with it that its not allowing me to adjust exposure/brightness , so i am only able to take picture in sun light ....other wise its almost black in all, i have already tried finding in settings and etc but there is no setting there , in the manual it says press right left keys but its not working. I need to know which chip set it has and which firmware version.I tried finding in manual and in player but i found no clue about the chip set or version. i am posting its pictures and specifications here and i want some one to help me solve that exposure problem.
From Front Click the image to open in full size.
From Back Click the image to open in full size.
From Top Click the image to open in full size.
2.0 mp camera
Built in memory 1GB + support for memory card
Music wma/mp3
video asf/mp4
Old 19th Dec 2007, 7:59 pm
Hi loog,
Do you mean the brightness on the screen you see on your player or the actual brightness in the photos you take with your player?
When you go into the "Setup" or "Settings" within your player, is there an item called "Info" or "Firmware"? It might give you a better idea of the chipset used and the firmware version.
Old 19th Dec 2007, 9:09 pm
Default Re: Not allowing me to adjust exposure/brightness
I mean that its not allowing me to set exposure in the camera and video recording thats why i can only take good pictures in sunlight...otherwise its pretty black..... The brightness of player is ok. i have checked setting etc but there is no version or firmware info in there only i see two notepad files one is in chines and other is in English that seems read me file of PMP Transcoding tool. Beside that i have tried to figure out from manual but nothing there about version etc. the manual tells about adjusting hue of camera , i.e press left and right keys , but its not increasing or decreasing the exposure of camera(not working).
Old 19th Dec 2007, 10:17 pm
Loog,
I have a camera with mpx player but these things unfortunately are not good at taking photos indoors , there just isnt enough light for that
The camera works great in sunlight though.
There is just no way around that bug and please dont upgrade your firmware as there is a 98 % chance that u will kill your player unless u upgrade from a reliable source example the manufacturers webpage directly, otherwise it just isnt worth the risk
Help with mp4 brightness... falchi Support and How To 2 26th Aug 2007 6:06 pm
brightness level sylar_jones Support and How To 3 19th Aug 2007 11:16 am
[SOLVED] Audio will not adjust avionik99 Support and How To 3 27th Nov 2006 4:59 pm
firmware brightness help capa57 Dead Players 6 27th Sep 2006 10:41 pm
Can we adjust the sound quality of AMV files? hongkie3 General Discussion 2 19th Jul 2006 2:20 am
