computer seems to be draining my mp3/4-help
Old 19th Dec 2007, 2:40 pm
Default computer seems to be draining my mp3/4-help
Hi all,
I've been having problems with my Mp4 player. For a while it would not be recognised by the computer then having left it to charge overnight in charger it finally reached half charge on the battery display so I plugged it into computer via usb and it recognised it this time. I managed to transfer some files (max 10 mins left attched) and then it cut out and battery was completely empty again and not being recognised. Is this normal? I thought being plugged into computer usb would maintain charge rather than sucking it out? Any suggestions? cheers
Old 21st Dec 2007, 8:03 am
This happens on certain USB controllers, it happened on my VIA PCI USB 2.0 card. There's not much to do about it unfortunately, it should work on another computer though.
Old 21st Dec 2007, 9:01 am
You might try and use an USB hub. (edit: one of those with the external power supply, suited for external harddisks and other draining stuff)
mp3 not recognized by computer paull Dead Players 13 29th Feb 2008 9:25 pm
my computer don not detect my mp4 last-hero Support and How To 4 28th Feb 2007 9:34 am
I see usb adfu but I can't see it under my computer tttbrian Dead Players 14 27th Jan 2007 6:51 pm
Would FW update help my Nanoclone battery draining problem ajh Support and How To 2 29th Dec 2006 12:59 pm
Won't connect to me computer Support and How To 1 9th Jun 2006 2:46 pm
