Karbon MP-821 1GB MP3 player won't connect to PC.....help
Old 28th Dec 2007, 2:54 pm
Default Karbon MP-821 1GB MP3 player won't connect to PC.....help
I bought a Karbon MP-821 1GB MP3 player for my daughter for Xmas and I can't get the computer to connect with it. The manual says it's compatible with Windows 98, which is what our system is (actually windows 98 2nd edition). I installed the driver from the disk that came with the player. I've tried getting the computer to recognize new plug and play hardware. I went to the manufacturers website but it doesn't exist. I phoned the help line and they told me to download a Microsoft Windows USB Driver and it should work (There was no USB driver on the Microsoft website that I could see).
Any ideas?????? I'm really frustrated!!!!
Old 17th Jan 2008, 8:08 am
Default Re: Karbon MP-821 1GB MP3 player won't connect to PC.....hel
I took this thing to work and it connected right away to my computer without drivers having to be installed. We are running XP at work. So what's the deal? The manufacturer says it works with 98 but it doesn't.
Old 18th Jan 2008, 1:04 am
bloodplague , there are few win98 drivers that you can try here:
http://www.mympxplayer.org/windows-9...15kb-df11.html
http://www.mympxplayer.org/windows-9...s-2-df228.html
http://www.mympxplayer.org/windows-9...s-3-df325.html
The problem with win98 and usb is that it is not as PnP-robust as XP where there is a large internal database of drivers.
How to get games on the Karbon MP-932 MP4 Player? Bullykai Support and How To 1 6th Dec 2009 8:17 am
karbon mp-828 2GBB organize images jakerman999 Support and How To 0 27th Jul 2009 4:54 pm
~Karbon MP-932~ Rockchip 2608A Help! Duraham Dead Players 0 19th Apr 2009 1:36 pm
Manual for Karbon mp3 player? lloydykins Support and How To 1 17th Mar 2008 12:53 am
My MP3 player can't connect victims Support and How To 3 14th Sep 2006 1:20 am
