i need help to know
Old 2nd Jan 2008, 2:48 pm
Default i need help to know
Hi guys i need help to know which firmware that mp4 clone has
a direct link to its firmware would be the best help
Code:
http://hackedgadgets.com/2006/12/22/ipod-nano-clone/
Old 2nd Jan 2008, 4:23 pm
Hi cyberman,
Unfortunately it's impossible to tell what firmware and version you have just by looking at the outcasing or even the menus.
Is your player working normally? If it is, then you can find out your firmware and it's version by going into the [Setup] then [File Info] or "Firmware" option with your player.
What a lot of the manufacturers of these MP4 players do is buy the same outcasing, however use different chipsets inside and some will have the firmware changed and use a different version on the player as well.
Old 3rd Jan 2008, 9:26 am
well i had the eact firmware but i have no clue what it was .. thats y i post te video maybe someone can give a clue which firmware it is i looked at the chipet it as a samsung722 but i already tried to flash it no go..i tried ome firmwares ended up with white screen... and button working .. but no menues etc .. (flash disk do get enabled)
i am not afraid to try out the firmwares .. since i am just doing i for hobby... so i was wondering if anyone could sugest me anything
