Volume down = volume up?
Old 3rd Jan 2008, 5:18 am
Default Volume down = volume up?
I have encountered something strange with my brand new mp4 player which is a Super-Talent Vidego28 (I got it 2 days ago). For its first 2 days of use on the 1st and 2nd of January, it worked fine and I even out loaded it with music, videos, and pictures.
But early this morning I was listening to music on it in speaker mode and come across an unequalized song of mine, I go to press the volume down button and it ended up increasing the volume... which was odd I thought considering it turned the volume down just fine before.
So I tried many things: restarting the player, soft resetting the player, hard reset, formating, firmware backup and then reload, & different firmware. But to no avail the volume down button still increases volume and the only way to get the volume back down to 20 is by doing a soft reset...
Is there any way to fix this without opening the player or do I have to send it in for warranty? (I do not wish to void my warranty just yet)
Old 3rd Jan 2008, 9:06 am
Opirian,,
u still got the warranty right??just send it back to them..for a replace...and dont tell them that u had reflash the player..good luck
waiting for exam results.
Hiss and low volume. mallen Support and How To 5 13th Mar 2007 9:21 am
AMV Volume issues mmginc Video related 5 23rd Feb 2007 11:38 pm
Cannot turn the volume up phpeters87 General Discussion 4 10th Feb 2007 1:03 am
volume??! jaidagr8st Support and How To 1 26th Jan 2007 2:57 am
MP4 Player Volume? Scooper Support and How To 7 4th Jul 2006 3:20 am
