Could a dead battery interfer with the player connecting?
Old 22nd Jan 2008, 6:34 am
Default Could a dead battery interfer with the player connecting?
When I plug it in, I get the switch on message. After I do that I get a fully charged message but no connection. If I don't switch it on, I get a charging message with a empty battery/charging image.
Could a dead battery interfer with the player connecting? Please somebody help me out here as I used it for storage last week and I need the files off it ASAP!
[EDIT] It's a loose usb port in the player itself that's causing the problem. I can get the connect screen on the player to show up but windows gives me a message saying unknown device but is not shown in the device manager.
Old 22nd Jan 2008, 8:17 am
redrosered,,
try diffrent usb cable..
waiting for exam results.
Old 22nd Jan 2008, 4:55 pm
Originally Posted by gaboon";p=&quot View Post
redrosered,,
Did that, didn't work. : |
Old 23rd Jan 2008, 3:24 am
redrosered,,
have u ever charged ur player..in wall socket..i mean not charging from ur computer USB Host..i'm not sure whether a dead battery will cause problem like this..
Old 23rd Jan 2008, 9:22 am
The wall charger doesn't work.
[Edit] The USB connector within the player is loose.
Old 24th Jan 2008, 6:26 am
redrosered,,
I do think ur player's USB port is loose and maybe because of poor soldering in the player..the best way is..u still have the warranty??i u have..ask for new one..
Old 24th Jan 2008, 7:00 pm
The USB port at this point is beyond loose, it's broken. And the warranty has been up for months so I can't take it back and ask for a new one.
Would getting someone to solder the connection to fix it or am I out of luck?
Old 25th Jan 2008, 6:37 am
redrosered,
u may ask someone to solder it back..but a good solder is needed for this..good luck!
dead mp4 player battery harbek Dead Players 1 16th Aug 2007 8:33 am
ERROR When Connecting Mp4 Player to USB!!! Yamcha Support and How To 14 20th Dec 2006 8:50 am
connecting problems/ please help mymp4 Dead Players 4 13th Dec 2006 7:26 pm
Problem connecting to PC keyonn Dead Players 3 13th Nov 2006 5:52 pm
DEAD PLAYER(battery?) Dulithak Dead Players 1 27th Oct 2006 1:23 am
