How to replace or fix a battery
Old 6th Feb 2008, 8:04 am
Default How to replace or fix a battery
I thought my player's battery was going dead. So when I took it apart, I notice that the wires from the battery are connected to the motherboard or whatever you call it. The black wire had came aloose and now the red wire is aloose. Is there a place that I can take it to get it fixed or am I better off just buying another one.
Old 6th Feb 2008, 12:00 pm
If you know how to solder you can do it yourself. If you don't know how, then take it to a mobile phone repair center, they will fix it for you. If they charge more than a few bucks for it then they're ripping you off.
Old 4th Mar 2008, 3:21 pm
Since our last email. I could not find a place to take it in my area. Is there a way that I can get a picture of where the wires are suppose to go on my 4gb Nano Clone. I took it a computer shop and he solder it where he thought it should go but I think he has the wires backwards.
Old 5th Mar 2008, 1:53 am
You can check it yourself.
I bet there are two signs + (plus) and - (minus) on the mainboard.
Black cable should be soldered to -
Red cable should be soldered to +
HTH
replace battery willyhehe92 General Discussion 35 5th Sep 2007 8:50 pm
How do you replace the battery? mpxguy Support and How To 1 29th Aug 2007 8:28 pm
Battery replace koschris Mods and Themes 1 25th Feb 2007 11:08 pm
replace battery wlazio2000 General Discussion 2 30th Dec 2006 10:50 pm
replace battery!!. nieuwe accu!!. Da_fixer General Discussion 0 3rd Sep 2006 1:24 pm
