GuYz Problem with my Battery
Old 10th Feb 2008, 7:21 am
Default GuYz Problem with my Battery
Hey every1 so i have a ACU7515 chip mp4player...
I had replaced my speaker coz it couldn't resist the current it got shorted( a useless speaker was smelling(short) wen i used loudspeaker)...
New one is just cool replaced by mobile phones repairer....
But it draws my battery power very fast wen fully charged approx 1 hr.
play 1-2 songs at 31 volume.
tell me wat to do ???
buy a new batt and my old one is a fixed one with red and black wire.
my battery is 3.7v 400mah (old)
Nokia battery wich 1??
Bl - 5b, 5c wich 1??
is problem with speaker shall i put a resistor. how much Ohms???
Old 13th Feb 2008, 10:56 am
ganesh040 , does your player currently use the external batteries like the Nokia ones? Or does it use an internal battery pack?
Old 15th Feb 2008, 9:49 pm
it uses a internal pack....
3.7 v 400 mAh
Old 15th Feb 2008, 11:39 pm
ganesh040 , do you frequently use the speaker? If you use the earphones instead, how long does the battery last?
Internal battery packs are a little trickier as higher capacities are difficult to find. Also, you'll need to check for the space allowed by the player to contain the new battery pack.
Old 16th Feb 2008, 1:27 am
Headset usally last 45 - 60 minutes and loudspeaker 4-5 mins only...
the baterry is really flat 1 might be .3-4cm thick and 5-5.5 cm long
Mp4 Onda clone battery problem dannylammy Support and How To 0 8th Aug 2008 10:15 am
please guid me guyz icemanbaz Dead Players 1 1st Nov 2007 4:41 am
Another battery problem KingGinola General Discussion 0 9th Jan 2007 1:10 pm
big battery problem flaviorodrigues Support and How To 9 27th Oct 2006 3:08 pm
Battery Charge Problem? General Discussion 32 31st Jul 2006 9:47 pm
