How to extract 9.1.52 firmware
Old 11th Mar 2008, 8:58 am
NSA NSA is offline
Am getting nowhere, been looking everywhere for 2 weeks, somone must have it pls?
Old 12th Mar 2008, 8:21 am
Default Re: How to extract 9.1.52 firmware
i tried on a different computer and it worked! my player is working. it seems some of you would need it. where can i upload the flash copy (its 80mb) ?
Old 13th Mar 2008, 7:22 am
NSA NSA is offline
Hi- you could join rapid share.http://rapidshare.com/ upto 100mb upload for free, that would be great if you can please!
Old 18th Mar 2008, 3:18 am
NSA NSA is offline
Hi- did you mamage too upload this firmware, still not found anywhere,
loosing hope now.
Old 18th Mar 2008, 1:36 pm
here you go
http://rapidshare.com/files/100554618/hg.fw.html
  #16 (permalink)
Old 19th Mar 2008, 2:47 am
NSA NSA is offline
Hi, thanks for that have downloaded, which prog did you use to flash drive with? have tried si clone & got error messages, also utilities ver 5.09
Says failed, any idea's, nearly there.
Cheers.
  #17 (permalink)
Old 19th Mar 2008, 6:16 am
i used s1clone for both, to copy the falsh and write it back to the dead player. i got some error messages but it worked.
How can i extract its firmware.. any help? kimbz920 Support and How To 2 7th Dec 2008 1:54 am
Extract firmware 9.1.52 Than and as? Sever76-1 Support and How To 1 27th Oct 2008 9:38 am
Can You Extract A firmware 9.0.48 baistosh Support and How To 1 4th May 2007 8:40 pm
firmware extract??? Camaro Support and How To 1 5th Mar 2007 12:44 am
how do I extract my firmware or is it even possible? squall458 Support and How To 1 4th Mar 2007 10:35 pm
