How to extract 9.1.52 firmware
Old 17th Feb 2008, 11:13 am
Default How to extract 9.1.52 firmware
hi,
i have an ipod nano 3rd generation clone 1,8". it was stuck at the hour glass screen, so i did the "dead player recovery". now i'm able to upload firmware. i tried finding the correct firmware for one week but none of them worked.
so i took the mp4 player of my friend which is exactly the same (we orderd together) and wanted to extract the firmware via the s1fwx tool and upload it to my dead player. this has to be the right firmware.
the problem is, that the firmware is 9.1.52, which cant be extracted with this tool. it always says "failure, unknown firmware".
is there any other way i can extract this firmware? other tools, or somehow manually?
some information to the firmware/player if you need it:
Ipod Nono Clone 3rd Gen 1,8"
Firmware: TJD_1223_20 9.1.52
Written on a chip inside: AK1025
greetings from germany, philipp
Old 18th Feb 2008, 5:15 am
Default Re: How to extract 9.1.52 firmware
my mp3 player same too
but it daed.
if you can extract please you upload firemware
Old 18th Feb 2008, 7:46 am
try to clone working one, and write it in your player (s1clone)
Old 25th Feb 2008, 11:39 pm
ne radi Clone na tome..
it doasn't work clone OK with that.. i need some tool for that also..
Old 27th Feb 2008, 10:52 am
hi,
i could extract the flash of the working one. its an 80mb big file. but when i try to write it onto my dead player with s1clone, my computer (brandnew, windows vista) always shuts down with some critical error that ive never seen before.
is there any other programm which can write the flash-copy to my dead player?
philipp
Old 29th Feb 2008, 4:45 am
Hi Guys,
I had a similar problem, now i have found a SW Version for my IPOD NANA CLONE, but it works to 90%, because i have a brand new Clone with the Original IPOD Connector with this SW it works but my keyboard ist not fit 100%.
http://en.s1mp3.net/
Search for BO-25002 or try any BO_AK1025 Version
Old 29th Feb 2008, 4:58 am
yes, i got "original" FW from suplyer, and when i put it on player - keyboard is jumbled..
i'll try your...
Old 6th Mar 2008, 9:23 am
nywww
I really really!! need you firmware.
Old 7th Mar 2008, 3:42 am
NSA NSA is offline
Hi. what a fantastic site this is, please please upload this firmware, i have spent weeks trying to find this match. I have tried loads without success,have got toa blue flashing screen , but thats about it.
I need TJD_1322_20
2007-09-27
9.1.52
2005-01-09
Thanks to everyone who uploads.
Old 10th Mar 2008, 7:09 pm
Originally Posted by nywww";p=&quot View Post
hi,
i have an ipod nano 3rd generation clone 1,8&quot;. it was stuck at the hour glass screen, so i did the &quot;dead player recovery&quot;. now i'm able to upload firmware. i tried finding the correct firmware for one week but none of them worked.
the problem is, that the firmware is 9.1.52, which cant be extracted with this tool. it always says &quot;failure, unknown firmware&quot;.
Ipod Nono Clone 3rd Gen 1,8&quot;
anyone help on extract this firmware?? i needs it too. TQ.
How can i extract its firmware.. any help? kimbz920 Support and How To 2 7th Dec 2008 1:54 am
Extract firmware 9.1.52 Than and as? Sever76-1 Support and How To 1 27th Oct 2008 9:38 am
Can You Extract A firmware 9.0.48 baistosh Support and How To 1 4th May 2007 8:40 pm
firmware extract??? Camaro Support and How To 1 5th Mar 2007 12:44 am
how do I extract my firmware or is it even possible? squall458 Support and How To 1 4th Mar 2007 10:35 pm
