Problems with battery
I purchased an mp4 player but the battery doesn't charge.
I tried leaving the player on usb for 6/7 hours but when I turn it on it says "low battery". I can't return it and i would use it more than a usb disk storage. Here there are 2 image of the player. Please help me... Thank you and ejoy Easter http://img509.imageshack.us/img509/6...0058uy1.th.jpg http://img178.imageshack.us/img178/1253/dsc00059ye8.jpg |
aragorn85 , when charging, did you ensure that the On/Off switch at the top is slided to the On position?
I thought it could be a problem with firmware, but I couldn't extract the firmware from the player to make a backup. If you have any ideas please post it. Thank you for your help. |
well...these chinese mp4s are a gamble..you'll never know whay you're getting...the other day my new mp4 charger exploded when I removed the cable...good thing the mp4 player is still ok...i'd say go for the name brands if you want a peace of mind,but if you're a risktaker like me,by all means, gimme the cheapest MP4 player available! :D
have you checked the battery contacts? if u have a soldering iron, you should consider re-melting the solder...that might do the trick. |
| All times are GMT -7. The time now is 7:59 pm. |
