Help, problem with a mp3 player with hynix memory
Old 1st Apr 2008, 8:48 pm
Default Help, problem with a mp3 player with hynix memory
Hi everybody, I'm new at this forum, I need a problem with my mp3 player, it have a hynix memory with capacity of 1gb, the design is similar like this
http://www.mympxplayer.org/image-asp159.html
without screen and buttons similars to ipod shuffle.
The player was functioning ok yesterday!
When I connect to the pc (I have WinXP with service pack2), plug icon appears but when I want to try access to info at the usb, windows return me an advertisement "the disk don't have format. Do you wanna format?" when I disconnect the mp3 player and push the button to play my music, it just try to play, but after a few seconds the player turn it off. What can I do? I'm a newbie at this topic, can you tell me what tools can use to check the status of my mp3player? Thanks a lot for the answers and sorry for my bad english.
Old 3rd Apr 2008, 9:21 am
Try any MP3 PLAYER DISK MANAGER and then format your player with that dont use the PARTATION AND ENCYRPTION option in that DISK MANAGER just format it and then it will work fine
4GB iTouch copy with memory problem - full memory dobo_d1 Support and How To 3 2nd Jun 2008 8:02 am
problem of memory sohih Dead Players 1 23rd Apr 2007 9:10 am
Memory problem SayNoMore Support and How To 3 1st Apr 2007 12:52 am
memory problem rjsoni21 Bad sellers/Blacklist 2 31st Jan 2007 11:51 pm
Osmium 1GB , 2'' mp4 player flash memory problem Zarko General Discussion - Uxcell.com 10 10th Jan 2007 6:45 am
