[U][b]Pls help! Wrong Firmware problem. MP4 player 2GB with
I received the player when it was showing bios information on blue
screen. I searched the internet for the proper firmware for BIOS-3221-MLC-SP1-(9320-5408-H-v8.9. I did not find that firmware but found one that is suitable for horizontal screen models. I connected the player to the PC while i kept pressing the menu button and releases immediately and pressed the vol button. I could find the 16 mb flash drive into which i copied the wrong firmware files. upgrading was successful but now I could only scroll through the buttons but could not execute any. Then i tried to repeat the same thing again by connecting the player to the PC but now I could not access the 16 mb flash files drive. Now when I connect the player to the PC the computer says new hardware found and displays two removable drives. One MMC drive and the other with four folders like AUdio, VIdeo etc... I am unable to format the player because i can only scroll through the menu buttons but can not enter in to any folders or go to settings section or reset section. Because may be the combination of buttons are different for the firmware that is now loaded into the player. Now, I need a tool that will give me access to the 16mb nand flash drive and erase the wrong firmware files from the player and upload the new firmware that you have sent me. When i tried the tools from the above mentioned links they are unable to recognise the player. I have tried all the versions but I keep getting a message the the player is not connected. Regards Deepak THIS IS MY PLAYER http://i245.photobucket.com/albums/g...player_321.jpg THIS IS THE FIRMWARE THAT IS LOADED INTO MY PLAYER NOW http://i245.photobucket.com/albums/g..._Player_wi.jpg |
| All times are GMT -7. The time now is 9:59 pm. |
