-   -   2GB limitation on MicroSD slot on player.... (http://mympx.org/forum/support-how/41050-2gb-limitation-microsd-slot-player.html)
WIZARD 8th Apr 2008 7:01 am
[SOLVED] :P - look in the main forum...
And what's about 2GB slot limitation? Can you brake it to use 4GB Cards for MicroSD slots? Or just using 4GB Card without any upgrades? (Rockchip) :roll:
