What card will fit in a vx858 player?
Old 9th Apr 2008, 3:03 am
Default What card will fit in a vx858 player?
Just got new vx858 that i bought on ebay, I thought it had 4gb of memory but all that memory must be in the mini disk that i did not get either!!!!! I already bought a sd card but its too big (wide) and wont fit in the slot!!!! What sort of card do i need??? Please help as i nearly have thrown the player at the wall!!!!!!!!!!!!!
Old 9th Apr 2008, 3:48 am
You need a MiniSD card up to 4GB max, standard NOT SDHC.
You should have got 4GB of board memory with this player anyway, you might need to format it first.
VX858 always have a minimum of 1GB, even with no card fitted.
Old 9th Apr 2008, 12:11 pm
thanks knob, it is meant to have 4gb, so how do you format the player?
Mp3 player with sd card ikepro Support and How To 4 3rd Jan 2009 6:18 am
[solved] Dead SD Card - card unreadable UzY3L Miscellaneous 2 19th Sep 2008 1:39 pm
Dita-232 MP4 Player with SD Card Slot 4GB fairy General Discussion 3 15th Sep 2007 1:27 pm
Putting video onto SD card, shows card error jignesh_1000 Support and How To 2 28th Aug 2007 7:51 pm
How is the best mp4 player with sd card slot?? tiobilyy General Discussion 3 10th Feb 2007 6:29 pm
