help with the charging of battery for my mp4
Old 14th Apr 2008, 4:04 pm
Default help with the charging of battery for my mp4
well..ive got a new mp4 and when i charged it took more than 1.5 hours (1/2 hours), that was specified in the users guide, for having the symbol of battery fully charged and then i used it and last very little...just like 30 minutes or something...the another day i tried it again and it was like the same and i really dont know what to do; to leave it charging more after the little symbol that says that the battery is full has appeard, to get lost with the mp4, to use it very little, to buy a new one etc etc.....so plz tell what to do or how can i solve it plzzz!!!!
Old 18th Apr 2008, 7:48 pm
raweclaz , it is quite likely that the battery itself does not hold its charge very well. Many such batteries made by these manufacturers are of low quality and usually not of the state mAh capacity.
A solution would be to swap the battery for another replacement. These could be bought readily and easily on ebay inexpensively. However, you'll need to take note of the replacement battery's size and ensure that it fits into your player.
Old 23rd Apr 2008, 8:02 pm
Default Re: help with the battery of my mp4
ok thx you
only the image connected and the battery charging pheonix1 Support and How To 2 26th Jun 2008 12:35 pm
battery charging vietnamesetan Support and How To 7 27th Feb 2007 2:47 pm
took 24hr to fully charging the battery sarden General Discussion 2 15th Feb 2007 4:21 am
Charging 3.6v Lithium Ion Battery? buts101 General Discussion 3 7th Feb 2007 6:52 am
IPod Clone not charging - Now battery is dead! jeromeof Support and How To 1 26th Dec 2006 6:53 am
