Onda Player stuck on battery screen after Flash
Hello I need help how can I fix my Onda player, this is what I did.
I flashed my Onda player with the latest VX858_V_0.0.21 after successful flash with Consumer Update 3.1, I restarted my Onda, and it showed me System ini... and then after couple of minutes I received the battery screen and a Chinese text under it, and that was it. I connected my USB and my PC detects the Onda as a flash drive where I can send files to it, but I tried using Consumer Update and I can't flash Onda it says "USB device not found." I followed the method of the tweezer and I opened the Onda this is the chip info SAMSUNG 813 K9G8G08U0M PCB0 ROCK CHIP: RK2606A I tried touching the pins from left to right on the ROCK CHIP, the only thing it does is restart the Onda and goes back to the USB connection or battery picture if USB cable is not connected, I tried pressing Update with firmware loaded in Consumer Update rapidly while Onda is loading but same info "USB device not found." I tried Soft mode nothing happens. Sorry this is a bit too long. but please help. |
Have you tried the reset button hole?
For help with hard recovery, here is a guide to help you:- http://myfreefilehosting.com/f/a6ae653b62_0.15MB Here is a long thread on MP4nation for this type of player which may also help you:- http://www.mp4nation.net/forum/viewt...&sd=a&start=60 |
Here is my PCB and chip layout please guide me, I tried following the steps but my Rock USB is not being recognised, when I touch those pins for the left and most right chip, the middle one is Rock CHIP. The screen goes white. When my Mp4 connects USB to PC as a storage I touch the pins on the chip and it makes the sound "Ke ching" or whatever, but then the usb pops up saying "USB Device Not Recognized" How can I fix that? Just now I messed around with the buttons, now I can see the Menu but everything in Chinese, when I touch anything it goes to a blow screen with a yellow Lock I am assuming or it looks like a briefcase. Onda Chip Layout |
Re: Onda Player stuck on battery screen after Flash
Now I attempted to the my PC to recognize the USB and isntalled the drivers for ROCK USB.
I installed Firmware-2.8TFT-1-8G-EN-80107_ONDAlook and it works now but I still get a lock image, I moved my On/Off from hold and vise versa nothing happens? did I mess it up? do I need to change something on the PCB? |
| All times are GMT -7. The time now is 3:14 pm. |
