Odd errors in flash memory and firmware
Old 30th Apr 2008, 10:54 pm
Default Odd errors in flash memory and firmware
Hello! I just discovered your forums in the search for a good AMV converter.
I have an MP3/4 player I purchased in March out of my productivity pay, and the firmware says this:
LG MP3 PLAYER
BKS25002
CM70038
2007/12/04
ACT_V9.1.52
I has an FM radio aside from a recorder function and MP3/WAV player. It has 1GB of memory. I decided to eschew the stock headset for a A4TECH headset with neodymium driver (like the one used for PSPs).
Oddly, it works just fine, but when I dumped the firmware using the s1wfx extracting utility, I also found out two errors pertaining to the firmware and the flash size, that the system cannot read from the specific device. Also, when I use Win98 to load MP3 files, it generates a write error and cannot save to disk. Something not visible with WinXP.
Is it compatible with the themes available on the forum? Especially that iPod look-alike theme.
Thank you for taking a look!
Old 4th May 2008, 1:55 am
Hi kenshinflyer,
You will have problems in Windows 98 if you haven't installed the correct drivers. If you get "write errors" then it might be a result of bad memory blocks on the memory chip or a case of a HACKED PLAYER (where the seller has hacked it to show more memory than it currently has installed physically).
You have a 9.1.52 version firmware which currently makes it very difficult to modify. The only tool available at the moment for modifying 9.x.x firmwares is the s1res tool which unfortunately won't detect all firmware versions and types.
Try downloading it from our [Downloads] --> [Tools] section on the left hand side menu bar to see if it works.
Old 5th May 2008, 3:27 am
I actually used the driver being used by my enclosures (this DATAONE driver) and it works. But despite the errors, it works perfectly so far!
It only has write errors with Win98, but it's gone. It perhaps isn't a hacked player because it only has 1GB of disk space (and it says there on the sticker)...or maybe it is a 512MB chip in there?
I guess I won't be modifying it to play safe...*sigh* I wanted that iPod mod...
Thanks for the help!
Old 5th May 2008, 6:13 am
Kenshinflyer, although it is becoming more uncommon to hack 1GB players, it is still being done. To be on the safe side, I recommend you follow the instructions posted here:How To: Removing a Memory Hack
My hacked player, which was supposed to be 4GB, had a sticker on it too. Turned out to be a 1GB.
2 GB Black Temptation Player
8) WHITE MEIZU M6 8GB
8)
Old 28th May 2008, 1:53 am
I actually used the driver being used by my enclosures (this DATAONE driver) and it works. But despite the errors, it works perfectly so far too!
Flash Memory usa6116 Dead Players 1 16th Aug 2007 11:19 pm
firmware and flash errors Da_fixer Support and How To 2 12th May 2007 2:18 am
Where and how to get more FLASH MEMORY green8 General Discussion 1 21st Nov 2006 4:28 pm
Is it possible add extra flash memory? HatNet Support and How To 2 12th Oct 2006 7:41 am
adding more memory on your mp4 via flash memory, possible? jb_jonas Support and How To 1 18th May 2006 1:25 am
