Pls help. Wrong firmware loaded. 2GB MP4 CAM FM
Old 3rd May 2008, 8:06 am
Default Pls help. Wrong firmware loaded. 2GB MP4 CAM FM
I received the player when it was showing bios information on blue
screen. I searched the internet for the proper firmware for
BIOS-3221-MLC-SP1-(9320-5408-H-v8.9. I did not find that firmware but found one that is suitable for horizontal screens. I connected
the player to the PC while i kept pressing the menu button and
released immediately and pressed the vol button. I could find the 16
mb flash drive into which i copied the wrong firmware files. upgrading was successful but now I could only scroll through the buttons but could not execute any. Then i tried to repeat the same thing again by
connecting the player to the PC but now I could not access the 16 mb flash files drive. Now when I connect the player to the PC the
computer says new hardware found and displays two removable drives.
One MMC drive and the other with four folders like AUdio, VIdeo etc...
I am unable to format the player because i can only scroll through the menu buttons but can not enter in to any folders or go to settings section or reset section. Because may be the combination of buttons are different for the firmware that is now loaded into the player.
Now, I need a tool that will give me access to the 16mb nand flash
drive and erase the wrong firmware files from the player and upload
the new firmware that one of my friend has sent me.
Tools I tried to upgrade the firmware:
http://mympxplayer.org/mp3-player-utilities-dc44.html
http://s1mp3.org/en/downloads_tools.php
When i tried the tools from the above mentioned links they are unable
to recognise the player. I have tried all the versions but I keep
getting a message the the player is not connected.
I have also tried firmware extractors and Easy FW software but no use they say device is not connected.
This is the frimware now loaded into my player:
This is my player:
Old 3rd May 2008, 2:18 pm
well dear as much as to my experiance you player has the ANKYA MAIN CHIP.The tools you are trying to use are not for the ANKYA chip players.The ANKYA chip always go to BIOS or you can say SOFTWARE mode by the combination of button .............as the comibnation you used before to access the 16 mb drive.That combination of button is the internal command and it is not dependent of any software version.Thats mean the combination you used before is always remains the same no matter you copy any firmware .So dont get panic and belive that the combination of the buttons are the same and not any wrong firmware can change that.So try again with the same old combination with the cool mind and it will work
No songs are loaded onto the player electrodug Support and How To 0 1st Apr 2008 7:46 pm
loaded music, but player says it has no files birdie Support and How To 2 22nd Jul 2007 7:05 am
99% Full with no songs loaded HvymtlC5 Support and How To 3 22nd May 2007 5:37 am
Not seen by my computer. Driver cannot be loaded manindarkness Support and How To 3 28th Apr 2007 12:32 am
MP3 isn't loaded when I change battery Dima General Discussion 0 2nd Dec 2006 1:52 am
