Battery issue on new player
Old 8th May 2008, 7:23 am
Default Battery issue on new player
I purchased a 4GB generic Hong Kong mp4 player, and it seems to work fine, except when I charge it. When charging the battery icon cycles to show it is charging, however, even after charging overnight, as soon as I unplug the player, the battery icon goes to solid gray (empty). I've used the player for over an hour straight, so I don't beleive it is actually dead.
Seems like a software/firmware glitch. Anyone else experience this? Here is what it says for firmware:
MP3 Player
BKSC91N014_30
2008-01-19
9.1.52
2005-01-09
Thanks for any and all help!
Rob D
Old 9th May 2008, 8:53 pm
Default Re: Battery issue on new player
Use AC adaptor for charging.
Set power switch ON position.
Old 10th May 2008, 1:27 pm
Charging it isn't the issue, as it seems to charge fine, and will play for several hours. However, just the battery indicator on the screen always shows empty, except it isn't actually dead. It's got to be a software issue. Has anyone successfully changed the FW on a 9.1.52?
Old 10th May 2008, 1:31 pm
Hi, do NOT upgrade your firmware. You will most likely brick your player.
2 GB Black Temptation Player
8) WHITE MEIZU M6 8GB
8)
Old 10th May 2008, 8:19 pm
Simply because mine is 9.1.52? or is upgrading FW in general dangerous?
Old 13th May 2008, 7:10 pm
The problem seems to have cured itself. I now show a battery reading. I did remove the cover to check the memory chip (got scammed, its a 2g! grr), and maby jarred something back into place. Anyways, I only paid $35 for this, so I think I still got a decent deal.
EDIT: Lol, I figured it out. When charged the battery icon is all gray. And as it drains it turns to the BG color, which happens to be blue, or green, depending on which screen you are in. Lol, it was all gray because it was fully charged. Poor choice of colors for the icon, but now that I figured it out, all is ok.
Rob D
EM2802A thomson player. Issue with connection to USB ambaran Dead Players 1 12th Jun 2008 1:52 pm
FPS Issue yngwie0001 Video related 3 23rd Jan 2007 7:52 am
BMP format issue Smarty Mods and Themes 1 14th Oct 2006 5:12 pm
Just got my mp3 nano clone- battery issue? Rocker81 Support and How To 10 10th Jul 2006 5:45 am
Firmware Issue Ko Support and How To 8 15th Jun 2006 4:11 am
