Wich exchange Accu/Battery ?
Old 5th Jun 2008, 2:54 am
Default Wich exchange Accu/Battery ?
Hi,
i am new to this Forum and got a question. I've got a 1GB 2.8" Onda clone.
Works well as long as it is plugged into USB and shows the Battery fully loaded, i can add songs etc But if i unplug it, its dead. I had it working once but it seems to be a Problem with the Battery, even if it seems to be fully loaded so...
If i want to buy a new one from ebay, what kind of battery should it be?
Thnx in advance
Old 9th Jun 2008, 9:05 am
try to take it apart then look at the markings on the battery.
hi...wich version of the MP3 tool works for update AK2025 ciasent Support and How To 1 27th Jan 2010 8:24 am
How To> Find out wich Rockchip? Tokuma Support and How To 12 8th Feb 2009 11:04 pm
Wich frimware do i have? acci Support and How To 2 11th Feb 2008 1:06 pm
How to change screen wich is visible during music play ALIEN Support and How To 3 4th Feb 2007 7:10 am
replace battery!!. nieuwe accu!!. Da_fixer General Discussion 0 3rd Sep 2006 1:24 pm
